Ispirisan nekim slikama koje su se vec pokazivale negde na temi za vlasnike kineza, a pokrenut malopre procitanim tekstom o prepisci sa Kinroad fabrikom resih da ponovo pokrenemo sad vec zaboravljenu pricu ali pomalo spominjanu (od sajma do sajma) ja bih voleo nesto od ovoga:
EEC/EPA Approval, new designed 400cc Dirt bike
Product size(mm): 2110*825*1340
Wheel base(mm): 1455
Ground clearance(mm): 140
Max. speed(Km/h): 140
Fuel capacity(L): 22
Seat height(mm): 820
Started system: kick/electric
Tire size: 110/90-16 / 140/70-16
Wheel type: light alloy / light alloy
Brake mode: Disc brake / disc brake
Brake operation mode: hand/foot
Engine style: Single cylinder, water cooling, 4stroke
Rated displacement: 386.8cc
Max. output power(Kw/rpm): 20kw/7500rpm
Bore*Stroke: 91*59.5
Ignition: C. D. I
Transimission type: chain transmission
EEC NO.:e4*2002/24*1941*01
Detailed Product Description
Product size(mm:)2210*790*1130
Wheelbase (mm):840
Mix ground clearance (mm): 180
Dry weight(kg):140
Gross weight (kg):190
Fuel tank capacity(L):22
Seat height(mm):820
Battery type:12V7A
Brake mode(front/rear):disc brake/disc brake
Brake operation mode(front/rear ):hand/foot
Engine type:single cylinder 4-stroke
Engine number:XY191MQ-2
Bore*stroke(mm):91*59.5
Displacement(ml):387
Compression ration:10.0:1
Max power/ running radius:22/7500kW/(r/min)
Rated power /running radius : 20/7500kW/(r/min)
Max torque /running radius:32/5500 N.m/(r/min)
Mim fuel consumption (g/kw/km):367
Ignition :C.D.I.
Product size(mm)2210x860x1200
Wheelbase (mm):720
Mix ground clearance (mm): 300
Dry weight(kg):132
Gross weight (kg):182
Fuel tank capacity(L):9.0
Seat height(mm):880
Battery type:12v/7AH
Mim fuel consumption (g/kw/km ):367
Ignition :C.D.I.
Jedino sto nigde nisam mogao pouzdano da nadjem to je cena! Ako neko dobro gugla neka dopise pa cemo azurirati.
Izvolite komentarisite i dajte mi vas model?!
