Engine
Ducati - L twin cylinder - desmodromic - 2 valves
Bore and stroke
94 x 71.5 mm
Displacement
992 cc
Max power/rpm*
91 HP@ 8500 RPM (67.6 kW @ 8500 RPM)
Max torque/rpm*
88.3 Nm @ 4500 RPM (65 ft. lb.)
Injection
EFI, 45 mm throttle body
Emissions
Euro 3
Gear box
6 speed
Clutch
Dry multi-plate with hydraulic control
Frame
25/20 mm Chromium Molybdenum (CrMo) alloyed steel trellis with aluminum machined plates
Rear frame
35/25/15 mm CrMo steel trellis with aluminum machined plates
Wheelbase
1425 mm
Front suspension
50 mm Marzocchi upside-down with TiN treatment
Fork inclination
24°
Rear suspension
Straight connection with full adjustable monoshock
Front
120 mm
Rear
130 mm
Avancorsa
100 mm
Seat Height
830 mm (32.6")
Pedal Height
430 mm from the ground
Front brakes
2 Brembo radial calipers - 4 pistons - 4 pads, double full floating, 320 mm disc
Rear brakes
Single disc 220 mm
Tires
Front: 120/70/ZR17 - Rear: 180/55/ZR17
Weight
170 kg dry weight
Evo prvi pravi konkurent za Aprilia Tuono.
Eee ljudi, ajmo ako se ubuduce ovako nesto desi, da zapamtimo Reg.broj auta, pa ga nadjemo i nalupamo ko p*c*u...Mina, de bas na tebe da naleti, da su naleteli na mene....sad bi imali rezervisana tri mesta u urgentnom.....
j*b*mti IDIOTE.....
