904 -
Sve što je postavio član: MILJAN*
Zanimljiva ideja.Reci mi koliko je bucna tvoja kaciga i imas li nekih zamerki.Da li je vizir otporan na grebanje?Ja sam moj Aeroh Matisse tako ebeno izgrebao da mi vec smetaju sare na viziru
Ne reče jel treba i da pere veš i kuva ručak... :D Kad bih imao na gomili 450eur za kacigu pozajmio bih još 9 i od Sekule poručio iz Luisa SCHUBERTH S1 PRO...i vozio se srećno za vijek i vijekov http://www.louis.de/_10a90422331410a6672a19a969662a6e0e/index.php?topic=artnr_gr&article_context=detail&grwgr=150&wgr=837&list_total=5&anzeige=0&artnr_gr=204844 Prevede google sa nemackog nekako: Schuberth S1 Pro ® - PREMIUM SPORTS Material: S.T.R.O.N.G. Fiber (glass fiber reinforced thermoset Special Matrix), 2 sizes of helmet shells Weight: Approx 1525g Sights: Pinlock ®, scratch resistant, clear, mist-free and integrated sun visor scratch resistant, tinted, mist-free Ventilation: chin and upper head area is adjustable and ventilation in the neck area Lining: MaxFit fit concept COOLMAX ®, and headband pad, removable Closure: Double-D closure Examinations: ECE 22:05 Other: Very quiet, integrated acoustic collar S1 - EXTREMELY LOW The S1 PRO is the helmet for the real athletes. Research in the wind tunnel S1 PRO gives a top-speed aerodynamics (lift = 0) and makes it extremely quiet - only 85 dB (A) at 100 km / h. The supplied default contained Pinlock ® visor Fingertape and ensures easy operation and freedom by fitting the double-disc principle. The helmet shell is made of STRONG-Fiber a special fiberglass-reinforced thermoset matrix and is available in two helmet shell sizes. Znam ja ovu kacigu a od nje sam odustao kada sam video koliko je teska i procitao nekoliko ozbiljnih tekstova gde je rezime da ne vredi toliko. Conclusion Is this the "ultimate helmet"? We don't think so. Although nicely conceived and very well made, there are some features that just don't work for us. The S1 is too big and much too heavy, in our opinion. -ovo je zakljucak jednog testa na http://www.webbikeworld.com/r2/motorcycle-helmet/schuberth-helmet/ The noise levels, while not unacceptable, are higher than we expected, especially considering the price and the design. While it may appear that we're being too hard on the S1, its high price justifies a very close look, and any faults that might have been overlooked in a helmet costing less become ,much more serious. A kod nas nema gde da se kupi ionako.Kupovati kacigu na slepo rezultira ovde na forumu prepurne oglase gde ljudi prodaju kacige iz Louisa gde su narucili pogresnu velicicinu.Npr. bas kod Schuberth kaciga je kalup specifican kao i dimenzije u odnosu na standarde l i xl. POstoje kacige u tom cenovnom rangu koje su od boljeg materijala-karbona.Kao na primer ona na slici koju sam gore izbacio.Bez obzira hvala na trudu i sugestiji.Ovde smo da razmenjujemo misljenja.Ima li neko bolji predlog od HJC fs10 solid carbon(420eu)?
Nemam obicaj da postavljam teme i zapitkujem ovde ali sad me vec malko smorila ponuda kod nas i uopste razmisljanje o full face kacigi. Ono sto meni treba je: **** full face kaciga,po mogucnosti od karbona,integrisane naocare,vizir koji se teze grebe i ne magli,c rna,da nije preterano ovalna vec agresivnog izgleda,da nije bucna,da se unutrasnjost vadi i pere,da ima dobru aero dinamiku i ventilaciju.Molim upucene za predloge sa,eventualno,informacijom gde to sto predlazu ima da se kupi kod nas.POzdrav i hvala unapred. Nesto ovog tipa:
Drugar i ja takodje picimo motorima na skup na Zlatiboru,pa posle produzavamo na more! To je extra ideja.JA sam bio do CG.Vratih se preko Zlatibora.Asvalt je super.Sa Zlatibora ka CG imate lepe krivine za peglanje.Posle je klasika.JA razmisljam da ponovim sator-dusek turu bas sa Zlatibora do CG ponovo.
GDE? Ako je na more....moze.... Sator varijanta.... ;D Ekonomicno i nomadski.... od 06.08. pa da 09.08.2009 varijanta ko kako savata sta ;D ;D ;D Ajd da ne drobimo ovde na PM mi salji vas plan pa da vidim da li se uklapam.
Ih Daki.On ti je mala maca. ;D Dosle one studentkinje a on pobegao kao da ga juri Konan. Vukan je bio zverka.Opasan je kibicer ;D
Kvalitet goriva i stil voznje.Ja jako pazim moj motor i kazem,ne zavrcem gas kao lud pri preticanju pa cak i menjam brzine pri preticanju.,,,,Rasterecujem ga maksimalno.On nikada nije osetio preko 5000 rpm a tih 5000 rpm je bilo par puta kada je bilo rizicno da menjam brzinu pri preticanju.Morao sam da se izvlacim...Inace vozim 80 km/h na nekih 3500-3800 rpm.Ispod 3500 rpm se gusi tj osecam vibracije koje poticu od bregaste.Tako da sam mu nasao optimum.
Sto se tice voznje: kod mene je bilo par situacija u povratku ali u Srbiji.Tip pretice kao da mene nema u traci.Otpanjim mu vazdusnu svirenu sa V Stroma i onda shvati da sam tu pa pocne da cima volan. Vukana je jedan kamion u CG saterao do ivice puta na isti nacin.Mada nije bilo u sustini opasno i ovo su izolovani incidenti.Odrona nije bilo.Put je ok. Zvezdane,znas da nismo bili tamo.BAscarsija....Meni licno nije zanimljiva ta sredina.Pitaj Mikulanca gde je bio...
Evo ovako.Kupio sam ga u MArkosu.Napunio pun rezervoar.Vozio 80-90 km/h /Presao 201 km.NApunio ponovo do vrha.Uspeo da napunim 6.6 l.Rekord . Sada u Crnoj Gori: Siapo pun.Posle 222 km sa 7 eu sam uspeo da napunim do vrha.Meni V-strom trosi jako malo.Da li je to stil voznje ili sta ne znam.Ono sto moze da bude od uticaja je sto ja jako cesto koristim menjac,rasterecujem ga uvek,vozim izmedju3500 i 4000 rpm i eto.To je potrosnja na otvorenom.
Neznam ali na Novi PAzar mi se nije islo jer mi je put dosadio a ova deonica mi se svidja...
Aha..da...Negde na Zaltiboru tj malko pre ste prosli...
Sto se zalis?Ajmo sledeci vikend dole? a? Ja sam uvek za akciju Odmor mi traje do kraja avgusta....
E vo,neki sms-om traze jos lika...dodajem...Vukan i Peca su ostali jos na moru..,Danas dolaze...bice slika ovde jos...
eh da....Motor,kinez Chelenger je popravljen tj. zavaren u Petak pa su otisli po njega.Peca je zadovoljan..Kada ga je dovezao nismo mogli da ga skinemo...Koja je to ljubav...Morao sam da slikam.. ;D
Mikulanac je prenocio u jednom od apartmana u blizini....Ujutro na plazu pa pedala kuci..Spremio sam bajk...Trosio mi je smesno malo..za ne poverovati.....Vetar je bio toliko jak da mi je skretao bajk sa idealne putanje,,,,U jednom obaranju me je totalno ispravio...Katastrofa od vetra se nastavila u povratku i kroz Kanjon reke Morace...Strasno kako nas je samarao...Isli smo istom putanjom kao i pri dolasku.. EVO I PAR SLIKA SA PLAZE PLAVI HORIZONT..CISTO DA ULEPSAM, KRAJ...
raspolozenje u vecernjim satima...Peca i Vukan..... ;D Vukan je preuzeo posao Sundjer boba-rostiljdzije... ;D Ove studentkinje( 3 komada) su dosle na Vukanov poziv...MArko je sacekao i pozeleo dobrodoslicu..Doduse,poskakali su svi da im pokazu gde se skrece u kamp..Nije im bilo tesko....Bas su me slatko nasmejali.... ;D
A poslednje vece u kampu,gazda MArko je odlucio da nas casti rostiljadom....Ponudismo da ucestvujemo finansijski ali nije hteo ni da cuje....Pripremio je carski....Osmeh na licu....druzenje,rostilj...njegovo ukusno crno vino,,,Kakavi ljudi..Opusteni,mirni i druzeljubivi..KOd MArka nam je bilo prelepo..Ovo ce mo ponoviti sigurno./...Vukanu dodjose i neke studentkinje....Odjenom se ,odnekuda pojavi i Mikulanac sa Miss M na bajku....Mislim da je iz Bosne dojurio...Nadje nas covek iz cuga.... ;D
Postoji i deo sa stenama do koga se lako stize jer je staza poplocana i uredjena...Ko voli stene i skokove moze ovde da se oproba..Naravno da smo otisli...Posle toga se vratismo na plazi...U plitkom delu Peca ispisa nesto....Voda je bistra....Plavi Horizont-raj za odbojku i frizmi na vodi..Jakoje plitko i lepo..Pesak je u vodio prelep..Nema ni jednog kamena...Kao da smona Havajima bili....
plaza....Inace na plazi ima "debelog hlada"....Borovi,restorani.....Za svakog po nesto..Cene nisu visoke....
Plaza jke blizu ali smo ipak krenuli motorima...opusteni...Hlad smo nasli...malko bezobrazno ali ljubimci zasluzuju najbolje Plaza Plavi Horizont je san snova.Na lepsoj nisam bio.Cista ,peskovita i lepa...
