zdravo, odgovorio mi je ovaj za auspuh, evo ti na ebay link,
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=370139801140&sspagename=STRK%3AMEWAX%3AIT&viewitem=
sa postarinom bi bilo oko 150 evra, neznam koliko ti se to isplati??
evo dimenzija, i izgleda, verovatno moze da ze napasuje na tvoj motor, ako te interesuje kazi pa da vidim za cenu:
NSR125, NSR150, NSR250, MC16, MC21, MC28
Specification:
Exhaust Length : 35 cm
Pipe Linkage Internal Diameter : 2.55 cm
Pipe end cap internal Diameter : 2.2 cm
Exhaust External Diameter : 6 cm
Exhaust Weight : 540g
za neki dan dolazim za BG pa cu ici kad prodju ovi praznici,
viziri koji odgovaraju za moj model kacige je
IXS Visor HX280-286+HX380-382
nadam se da ga imaju na lageru.
nije prevara, nasao sam na netu uz pomoc tvog linka, hvala
radi se o modelu Phoenix R2 200ccm
Detailed Product Description 1. Engine: 200cc; 125cc available too
Type: Vertical,single-cylinder,4-stroke,water-cooled
Bore x stroke: 63.5 x 62.2 mm(197cc)
Compression ratio: 9.2:1
Max Power: 12.5KW/8000RPM
Max Torque: 15N.M/6000RPM
Carburetion: Keihin PZ26
Ignition: CDI
Clutch: Manual
Start: Electric start
Transmission: 5 Speed
2. Chassis
Frame: High Tensile Steel Frame
Brakes/Front: Double Hydraulic Disc Brake
Brakes/Rear: Single Hydraulic Disc Brake
Front Suspension: Inverted Hydraulic Front Fork
Rea Suspension: Mono Spring Shock/swing arm
Front/Rear Tire: 110/50-16; 140/50-16---Tubeless
3. Dimensions
Length: 1810mm
Width(handlebar): 680mm
Height(windshield): 1010mm
Seat Height: 820mm
Wheelbase: 1250mm
Ground Clearance: 200mm
Tank Capacity: 10L
Max Speed: 130km/h
Max Load: 150kg
N.W/G.W: 95/115 kg
Packaging: Inner--- Iron Frame, Outer---Carton
Carton Size/Quantity: 1810x680x1010 mm(whole bike packing)
18PCS/20'GP; 38PCS/40'GP
Carton Size/Quantity: 1780x470x880 mm(disassemble handlebar)
32pcs/20'GP;96pcs/40'HQ
vise ovde
http://www.cbrforum.com/m_341891/mpage_1/key_/tm.htm
